I've been looking at buying a more modern attenuator than the basically a big resistor network thing I have now.
One of the units I've been looking at was the rockcrusher recording, and I thought I'd ruled out the likes of the 2 notes torpedo reload, until I started finding threads on issues with squealing from some rockcrusher units that Rivera don't seem to be able to explain.
So I looked a little deeper.
Both units are reactive loads, but the the 2 notes Reload reactive load feeds a built in power amp whereas the rockcrusher does not.
So it's said that the reload isolates the speakers from the amp and that there is no longer any amp/speaker interaction, whereas the Rockcrusher does not isolate.
Can anyone quantify speaker interaction for me?
Does this even make a difference if the 2 notes power amp is a wideband hi-fi power amp? Should it not faithfully reproduce and amplify the amps signal which is then filtered by the response curve of a given speaker?
If the point of a reactive load is that the amp sees a "speaker like" impedance in the attenuator, is the rockcrusher not isolating the amp from the speakers to an extent also?
A bigger problem with most conventional attenuators as that as the level goes down, the damping on the speaker increases - this is what's mostly responsible for the 'strangled' sound that attenuators often cause, and probably why some people think the load/re-amp systems sound better. In fact, it would be possible to design this problem out of a conventional attenuator, but as far as I know it hasn't been done.
