Personal fave is the old 2 knob mxr Envelope Filter. The CKK Q cat is also very good once you've played with the controls a while. The Maxon AF9 has a nice sound but I found it tricky to operate (guitar volume very handy with this one).
Or the ancient Electro Harmonix Zipper if you can find one!
One solution is supposed to be to calm them down a bit is with a compressor after in the chain. You may/ may not be in a position to try that.
A 2 in 1 auto wah and compressor seemed an obvious pedal design to me as when you think of either it's often for similar musical styles. However, I've never found one yet. Any budding pedal designers out there you can have that idea for free...
The 440 is a bit less extreme than some others so may well be a good choice for the OP.
Mind you, I should fess up here and say that I use it to get those Steve Hillage-style Mutron-type sounds for solos, rather than that 1970's cop show 'frying egg' sound.
