The best one for that amp is probably the Marshall Powerbrake - not available new (why, Marshall?) but not rare second hand.
5-6 is about where they usually go into power stage overdrive assuming the preamp is already overdriving.
Does anyone use these for gigging? I have quite a few amps but always come back to this one. What settings do you use. Without using the attenuator (volume around 4 still not opened up) i find i have to set the preamp to 8 so it adds bass...otherwise the bright cap makes it sound thin in my band mix. With the attenuator i wouldn't go more than a couple of clicks so maybe master up to 6 to get the power valves working and preamp back to 6 or 7.
Do you think the thin open back cab contributes to the thin sound at lower volume?
What speakers are you using btw? If they are G12H 30's they are very efficient @ 100db. Iv got G12-65's in mine. not so efficient @ 97db so the master volume can go up a bit higher (or -3 instead of -6 on PB). They also dont sound as in your face as the G12H. (Iv got a 2045 2x12 cab with G12H in and it takes yer head off)
Marshall did fit them with G12M-25s until about 1979, but they are prone to being blown. G12-65s after that, which are totally reliable and also sound better in the combo in my opinion.
For a 4x12”, G12M-25s are fine and sound a bit better than 65s to me - the 4x12” doesn’t need the slight extra bass and smoother treble. (And needs less bass on the amp too.)
Having the preamp volume too low makes the bright cap on the pot too effective as well. I think that's why I prefer it with the preamp at 10 (no bright cap, effectively) with Fenders and at 8 (a little treble boost) with Gibsons, as much as the difference in gain.
I thought those treble peaking 470pf/470k (I think) paths on V1, and both sides of V1 being in series were the 800 sound.
Personally I think it's critical to the classic rich/ringing Marshall crunch sound, which is one reason I've never thought the Jubilees sound quite 'right', although I know not everyone agrees with that.
It can also cause trouble with some valves, Russian-made 12AX7s don't have adequate cathode-to-filament insulation and often fail at the higher cathode voltage, and I've also come across quite a few JJs.
Essential imho - these amps are very conservatively rated at 50w ... :-)
