It’s not often used in guitar amps but two which do are the Marshall Popular and some versions of the WEM Dominator, although I think the WEM was designed for the similar ECL82. Both of these will need a pair though, unless you’ve got one with an obvious failure in one valve and the other is OK.
The ECL86 belongs to a group of triode pentodes. ECL80, ECL82, ECL83*,ECL86. The 86 is the best of the bunch being used in the more upmarket record players and radiograms. The "Blue spot" RG was a famous must have for the regge boys, ECL86 in pp per side and four, iirc, ten inch speakers to woomp well!
*A truly awful valve. Compact but that was its undoing it got very hot and cooked everything around it. The PCL83 was the CTversion and was similarly unreliable. (there was a PCL84. Not sure if there was ever a 6volt heater version?)
Make nice little practice amp would an ECL86.
Dave.
The sting in the tail in the Mully design these days is a suitable output transformer IC. Must of course be a "gapped" stack intended for single ended operation and they tend to be expensive . Had a very quick look at Sowters...Wheee! a nifty. Of course these are "hi fi" traffs so it might be possible to use a Fender Chap SE component. Anytime any of you are looking round car boots etc , don't pass up old radios if cheap enough. Even if well battered and dead the SE optraff is very unlikely to be faulty. The mains traffs in the bigger radios were also very reliable but if you use one for a project amp you must get it PAT tested.
Dave.
They’ve been selling those since at least the 1960s - I’ve got one with the old Radiospares ‘running man’ logo on somewhere.
Cor! Never thought Rad Spad were still doing those transformers! Used to be called the "Universal Output Transformer" I think and I have a bigger one on a chassis in the loft for PP EL84s and EL34s.
There were a few radios (and tellies) that had rather feeble OPTs and the RS ones were used and I never knew one to fail.
Dave.
