Ring mods
CorvusCorvus Frets: 2925
in FX tFB Trader
Thinking about the Subdecay Vitruvian or maybe EHX Ring Thing, anyone had these, any thoughts? Seems bleed through(?) when turned off is a thing with ring mods, I wouldn't know, or if these two have it. The EHX has presets and expression which seems great but not keen on the size. The Subdecay seems like it has good sounds in there but no presets or exp, small size in it's favour.
Randy's Revenge is too much cash and I've not heard anything I like in the Way Huge demos. Any others to look for?
  • There is a Minifooger one and you can plug an expression pedal into it. Not too sure it’s made anymore but you might turn one up.
  • The moogerfooger ring mod is brilliant. A stunning tremolo that can go very mental
    Only one I ever liked was the Ring Worm. It's bonkers.
    It's hard to tell from a demo vid how usable it is. Takes a lot of playing around with the controls.
  • Paul_CPaul_C Frets: 7778
    I've got a Vitruvian Mod, which I like a lot. It's silent when off.
  • I hope Major Thorpy and Lovetone Dan make some kind of successor to the Ring Stinger.
  • octatonicoctatonic Frets: 33793
    Frostwave Blueringer if you can find one.
  • merlinmerlin Frets: 6674
    I have a Moogerfooger Ring Mod. I never use it..... Want it?
  • JD50JD50 Frets: 658
    I had the Ring Thing. Lots of fun does more than ring mod and you can tune the modulation and save presents...  I never found a use for it with the band but spent hours at home making horrible noises.
  • CorvusCorvus Frets: 2925
    Cheers all. Thinking I like the Vitruvian most so far but demos of all of the above are a right mixed bag. @Paul_C if you want to sell let me know. @merlin cheers, will listen to more demos later and drop you a PM.
    Sorry, it's not going anywhere.
    No worries :)
  • benecolbenecol Frets: 399
    edited February 2019
    I've had quite a few ring mods (notably the CoPilot Android and EHX Frequency Analyzer) but the Ibanez PM7 (from the same range as the DE7) is the one I keep coming back to. Cheeeeap, too.
    @merlin I'd be interested in that ;-)
  • FunkfingersFunkfingers Frets: 14423
    I have an EHX Ring Thing. I shall have to test it for bypass mode audio leakage. I only use the pedal for home studio experimental muzak.
    @merlin thanks but don't think the Moog is for me, @meltedbuzzbox over to you.
