https://i.imgur.com/7EGBp9H.jpg
I had 3 Prosonics at one point (from 2009 until 2011) and I had several mods for them from Fender that I performed (well, a tech did it) to try to sort channel switching issues, noise in the reverb and made the clean a bit crunchier.
The loop is the problem with this amp for the reasons you outline and it was why I moved away from using Prosonics.
The best case for me was using multiple amps in W/D or WDW, but it was a lot to carry and when I sold them and went for a CAA PT50 I had a much easier time, as the loop is so much better in that amp.
Interesting that you are using the SS rectifier with this amp.
I used to as well.
Some form of level matching might help.
You will need some sort of attenuator to go into your modulation effects, then some sort of amplifier to get the signal back to line level to to go the power amp.
A re-amp box (such as a Radial X-Amp) might work.
What I did was use rack mount multifx that worked at Line Level to try to get around the issue.
It sort of worked but the loop is still not great in the Prosonic.
For a while I used the Axe FX into power amp return of the Prosonic.
That sounded pretty good, but it bypasses the Prosonic's preamp.
They are great amps and I plan on buying a head again when one comes up for sale for non-stupid money, but purely for recording.
I don't think I could gig one now- way too loud.
