FS: Heyboer Mojotone Marshall output & mains transformers JTM45
Selling these two transformers from a build I did. They are Heyboer’s from Mojotone. Amp builders will know all about these – very high quality transformers for a Marshall style build. These are for a JTM or variant (I used them in an Egnater “seminar” amp, a JCM800 clone).
Output is: HTS-8113
Mains is: HTS-7134HV
Work perfectly and very good condition with plenty of life left in the leads. Only issue is that the tip of one of the screws on the mains transformer sheared off because I overtightened the nut (see pic). No big deal but easy to replace if you wish.
Come with spec sheets and mojotone boxes. These are £85 each in the UK. I'm asking £100 for the pair.
Please PM me if you're interested.
Cheers, Steve
