I got my Epiphone dot that I discussed on a previous thread and it genuinely played better than the Gibson ES 355! I think it might have something to do with the fact I am bot a massive fan of binding. But the Gibson sounded much much better - more clarity, less muddy, more articulate etc. So I am looking to upgrade the bits that might make this sound better. I understand that it won't ever sound as good because it's not the same guitar but there should be room for improvement. This is where I am looking for advice as I have zero knowledge on guitar electronics.
Any recommendations for pickups?
Also what else do I need to upgrade? wiring harness, tone pots etc?
I will ask a tech to undertake the work but want to know what to ask for.
Thanks!
You also need to figure out what kind of pickup you're aiming for. As the Dot is a semi-hollow I presume that you're interested in lower output humbuckers, but you might as well want to considder a pair of humbusker sized p90.
I'm not sure what quality Epiphone use for the other electronic parts and if you need to change anything here. Hopefully someone else with a little more experience will chime in here.
Bridge/Treble - something a little bit hotter, UOA5 magnet.
A500k pots. No 300k!
Its the semi hollow faffs that have put me off so far!
