Other places beside Thomann sell it.
Thomann will charge you 9€ delivery which makes it expensive on it's own.
If you go for this, let me know and I'll split that delivery cost with you, there's a couple of cheap parts I need from them too which would cost £1 postage in the UK to send on to me when they arrive?
Let me know...
The most likely is that the existing foam has crushed and broken down so the pickups are screwed in too far.
Thanks for that ..... will check it out .... oh, I see..... OK.... I have just the very same dense foam as that , so will give it a try. Sorry I cant help you out with the Thomann thing!
It sounds like new foam will make it more useable again.
Good luck.
