Hello
I'm thinking of buying a secondhand Tom Anderson Atom Special but I've noticed that the neck has a full length shim, factory installed as far as I can tell. It means that there's a small gap between the edge of the fretboard and the body and it's necessary to get anything like a normal to low action (5/64ths at the 12th fret on the bass E).
This seems really odd that a maker with such a reputation for high quality wouldn't cut the neck pocket correctly in the first place.
So, the question is: did your Atom Special have a shim, and do you have any opinion about this?
Thanks, Max
https://www.instagram.com/insta.guitarstuff/
When I told him he changed his mind and said they did! So, still begs the question about why the pocket wasn't cut correctly in the first place. Sounds great though.
