I'm pretty sure you've all seen my Chibson thread by now, I wanted to separate this section from that one though as this deals entirely with optional modifications that I've made (and planned) to the guitar already, so it isn't fair to judge the changes against the original.
Here's a reminder of how it looked from the factory;
Prior to ordering the guitar, I had a planned set of modifications that I would be installing anyway (Completed mods in bold);
- Truss-rod Cover
- Nickel tailpiece
- Pickguard & "proper" mounting bracket
- New wiring loom
- New pickups
- ABR-1 M8>M4 bridge post converters
- Non-wire TOM with nylon saddles
- New Tuners: either Kluson Keystones, or Hipshot open-backs
- Ebony tailpiece block
First up was to sort out the truss-rod cover. The original was installed a little wonkily, but fortunately I had a spare lying around that I thought to try before attempting a repair. The new one is a different shape (I think it's from StewMac?) but that seems to reduce how noticeably off-centre the top screw is, and I really like the look so this one's staying. I'll probably drill a new hole and straighten it out eventually, and then plug the original hole, before drop-filling it with black & clear nail varnish at some point.
Here's a side-by-side comparison;
I'd ordered another tailpiece in advance too as the stock one would be chrome, and lacked the embossed diamonds of the original Trini's. I think the diamond really helps tie together the rest of the guitar and it was fairly cheap to source anyway. I managed to find a Nickel version at
WD Music, the only difference is that the bracket part has a slightly different screw spacing to the original so I'm using the stock for now until I re-drill it.
I could have had a pickguard installed at the factory, but I wanted to use the Gibson Mandolin-style bracket to mount it. The parts were from Allparts UK, but the pickguard needed a bit of filing first. It had been undercut for standard pickup rings, and the gap between the pickups on it was too short as well. The mod only took 15 minutes or so to get the fit correct, and the pickguard was very cheap so I don't really mind, the effect is certainly worth it.
The guitar arrived with the usual mini-pots, poor/no tapers, and cheap capacitors. The stock toggle was quite nice and I would have kept it, but I had a Switchcraft one lying around to use up. I dropped in 4x CTS 500k audio pots, (vintage-back versions as I like their feel more than the standard ones), 2x .22uf Orange Drop caps, and a Switchcraft output jack to finish it off.
I dislike soldering at the best of times, hence why I ordered this with the rear-access panel. I'm already glad I did as I had a strand of solder short out the switch for a few hours before I found the fault! I had to ream out the top to fit them but that was made much easier by removing the access-cover and using a standard hand-reamer. I'd have probably just filed them out otherwise.
I hadn't thought to check if the stock silverhat knobs fitted the CTS pots (they didn't), so I ordered some witch-hats for a change - they're technically correct for a Trini anyway and they feel nice even if they do look a little different.
Here's an updated shot of it;
such as cavity differences, pots, frets, binding, shape, cutaway etc.
Lovely guitar btw, if it helps my actual Gibson LP has a wonky truss cover.
