https://www.disasterareaamps.com/shop/pba-4
You'd have an input, output, loop send and return for the wah pedal. Use switching jacks for the loop in/out and wire the switched contacts together. Then if nothing's plugged in to the send/return jacks the signal passes straight through.
Even simpler but uglier- use four regular jacks and just replace the wah pedal with a short patch cable when not in use.
