Hey kids.
I have a very compact pedal board for a band that I play in. It goes:
Boss TU2 > Stone Deaf PDF-1 > MXR Carbon Copy
The PDF-1 is picky about power, but I've found that it likes the One Spot. What I had wanted to do was power the tuner, and then use one of those 2 into 1 cable adaptors - that allows you to sum two 9 volts into a single 18 volt pedal - reversed, coming out of the tuner into the two pedals. It does work, but introduces noise into PDF-1 when its engaged. Is there any reason why that might be happening? I can just daisy chain of the One Spot, but that's messy as all those daisy chain things have at least 5 plugs attached. Powering each of the tuner in isolation is perfectly silent.
Thoughts?
Noise, randomness, ballistic uncertainty.
Similarly, using the tuner's power output is physically identical to using a daisy chain cable - it simply splits off the power input, there is no isolation or 'independence' there at all.
I recommend buying either a 2 or a 3-way daisy chain (you can buy them cheaply on ebay/amazon with virtually any number of plugs), or alternatively use something like a Gigrig Distributor. Another option would be to use one of the new low-profile Harley Benton ISO isolated power supplies, which may fit underneath your pedalboard, and will offer fully isolated power to each pedal.
Anybody else found Stone Deaf pedals need clean isolated power?
Tate FX
www.TateFX.co.uk
Instagram
downbytheriver said: I might well pick something up. I have these three pedals on a Pedaltrain Nano so there sod all clearance underneath, and little space on top.
Makers will only stop building poorly-designed pedals which won't run properly on power supplies when people stop putting up with it. There's really no excuse.
I actually contacted the Manufacturer and they had no idea why I was getting the additional noise. Maybe I got a duff one.
I used to have a Gigrig G2, and went all-in with the GigRig power supply system (isolators, high-current supplies). I sold the G2 so no longer have the Generator, but I kept all the other stuff and use it with a couple of Johnny Shredfreak switching PSUs on my smaller boards. I simply don't ever worry about noise from the power supply.
R.
Eqd Speaker Cranker clone
