Helix delay clipping
PolarityManPolarityMan Frets: 7284
Do you guys need to attenuate going in to any delay block? I get distortion / clipping on most models if I don't...seems more prominent on higher notes.
Are there any meters tucked away anywhere?
ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • sgosdensgosden Frets: 1994
    There's a video on YouTube about gain staging. It could be that you're putting a too big a signal into the delays.
  • simonksimonk Frets: 1467
    Some of them have a headroom parameter... turn it up.
  • PolarityManPolarityMan Frets: 7284
    Hmm well i get it even with jsut 1 delay block and nothing else going in to the front of an amp, I wonder if my guitar is too hot..it should be though tis jsut an LP with burst buckers but will try the input pad...im also running the master volume at 12 o clock rather than full but i guess that isnt the unity point
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    could be why my 4cm experiemtns also had issue too
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Are you sending line level out to to amp?
    yes i was, jsut switched it but wont be able to test till tomorrow
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Definitely try using the pad, and let me know how you get on!
    Bye!
    well i made an empty patch and used the USB output into reaper as a meter and it def  isnt clipping without the pad.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Which delay are you trying it with? Have you recorded the output and looked at the waveform close up? Does it look squared off?
    Bye!
    not tried that yet but its on my list, happened with several, vintage digital, adriatic, memory man, dont recall them all.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
