If youre using your Tubescreamer simply as a boost for your amp, it might work.
Looks ace too
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
I am assuming you want to stack your TS into the Fulltone?
I used to pop mine before my wah and tuner. I did have an archer pedal at the time, which has a buffer. It was ok on my rig if it was down the signal chain. In front the 69' sounded as you describe.
Hmm .. it's weird. I know the accepted knowledge is that a buffer after a fuzz face doesn't matter but with the pedals I've had, it did make a difference! And I wasn't being Eric Johnsony about it!
So, I had a RYRA klone and a boss waza tuner. These are the only pedals with buffers I've owned.
Placing the RYRA before or after the Fulltone 69 gave me the same trebly sound. The only way I could use the Fulltone 69 and Ryra on the same board was to have it as an always on clean boost, then the Fulltone 69 sounded as expected.
I experienced the exact same thing with the Boss Waza tuner as well, before or after it spoilt the sound of the Fulltone 69. With the tuner I left it at the start of my board and simply switched the buffer on and off when needed.
I don't know if those buffers were just unique, is there any possible explanation for it? I've never actually owned a buffered tubescreamer, perhaps those buffers were different?
Yeah a custom made one from someone on the forum would be a great idea! Something I will consider!
To clarify how I'm using it, I'm using the TS after the Fulltone 69. It's used to boost a Greer Lightspeed for lead tones.
Thanks again for all the wisdom guys.
With buffers - As soon as you turn a pedal on, any pedal, your signal becomes buffered. The true bypass/buffered thing refers to when a pedal is turned off. If you’re not using the TS and the fuzz together, but you don’t like the sound of a buffered pedal (not turned on) after the 69, any true bypass TS will work, and will not affect your sound. Why would you want a switchable buffer if buffers seem to react badly with the Fulltone? I’d just have an all-tbp board and be done with it.
Some pedals just don’t like to see buffered signals - a lot of Lovepedal overdrives sound horrible if there is anything turned on prior to them in the chain, but they can also react if you turn something on further down the chain too. Some Way Huge buffers do the same. Someone smart will be along in a bit to explain why!
Thanks the info JDE, honestly that’s was technical enough for me - that sheds a lot of light on it as obviously the fulltone 69 has a lot of gain!
Reason for wanting a buffer is so I can have a slightly brighter signal/non degraded signal when all the pedals are off. Which I admit is rare. I currently do have an all true bypass board with the tube screamer mini fulfilling the TS duty!
Don't understand why they're so popular.
The “purest” way (hahaha) is you could put your whole chain in a loop and switch it in/out as you like, using a looper pedal.
Other option would be a dedicated buffer pedal with an on/off switch at the end or start of your chain. Again, most buffer pedals have no footswitch as they’re designed to be “always on” so you may need to get someone to knock one up for you.
This really isn't true. The pedal can't 'see' that there's a buffer after it and the buffer doesn't affect the sound of the pedal - it's simply a high-impedance input, the same as an amp. The difference is in the length of cable between the two - if you put the pedal on top of the amp and connected it with a short patch cable, you would get exactly the same result.
The best solution to this is to use a buffer after the '69 and set the amp to give you the sound you want, then it won't change when you turn the pedal on.
Basically, true bypass causes more problems than it solves because it doesn't account for cable loading.
Interesting @Sassafras - Which ones have you had? I've only had the Fulltone 69 and the Octafuzz - I liked the Octafuzz but like the 69 more! It's now a never sell pedal for me - hah I mean, I'm going to all this trouble and causing you guys a headache to keep it on my board!
I'm quite drawn towards a Tumnus Deluxe to fulfil this role! Pros are that it would fit on my board and it has an external switch for a buffer. Cons are - it's not a tube screamer! It might work nice to boot the Lightspeed though.
@ICBM - Hah I've read one of your others posts about the OCD and that quirk! Maybe that is the case with this! Thanks for the input.
Crazy how complicated this is - definitely leading me to develop an obsession!
I haven't tried the Octafuzz or the 69 but my experience of the others means I don't have much confidence in the brand.
Only because guitar pedals aren't all properly buffered. If they were there would be no issues whatever...
