The One Spot is a *great* daisy chain in my opinion, but certain pedals just don’t like to share power.
You need an isolated output power supply.
Of the more well known / trusted brands that do a unit that will fit under Nano+, there is the Voodoo labs X4 and PedalTrain make one too, the MXR mini iso brick also looks good - I saw one of them at the Guitar Show in Birmingham and I was surprised how tiny it was. All of these are around the £100 mark.
I took a gamble on a Vitoos ISO 4 which was a lot cheaper than the rest (about £25) and so far it has worked out OK for me. Although you have to find your own AC adapter to actually power it - I had one lying around at home that works well.
Hmm - I've got 3 digital pedals on that board. All of them contribute their own little bit of noise, but the Pitch Fork is definitely the worst offender. The TC HOF2 is surprisingly quiet on the daisy chain.
So I guess this means that I need to get a proper isolated power supply. Boo - I was hoping to avoid that expense.
Truetone CS6 looks like it would do nicely, whilst also offering that advantage that if I do upgrade my board later I have an extra outlet. Is that a good one?
I'd be inclined to spend the extra wedge on something like this rather than the sketchy cheap Chinese brands. I'm not convinced that all of those are exactly what they claim to be, particularly in terms of what's isolated from what.
The CS7 is totally quiet and all the outlets are isolated from each other. I don't see any reason why the CS6 (which would work better for the OP) would be any different.
IMO most guitarists who like pedals will eventually run in to a situation where isolated power is required. Better to spend a chunk of change once on a decent isolated PSU.
Also, FWIW it's possible to daisy chain multiple pedals from each of the isolated outlets, so you're not actually limited to one pedal for each outlet. Just need to make sure you stay under the current limit, which at 500mA x 5 outlets on the CS6 is a lot of analogue pedals.
