My Dual FS Hudson Broadcast has basically 1% output, if that.
It's been in its shipped bag and never even put on a board or gigged, so its absolutely immaculate.
I've finally got into a band and I want to use it this next weekend to record some basic stuff with them.
I went to try it this weekend on its own, straight after using the power supply with a Thorpyfx pedal, and it's got no signal.
Bypassed works fine. The LEDS light up. but zero volume or sound unless you crank EVERYTHING to 100% and then you can JUST hear a tiny noise coming out (sounds out of phase)
I've contacted
@NorthernStomps and obviously I know I'll be sorted out by them or Hudson, but it IS weird....I'm stupidly careful with pedals and gear....is this just back luck?
EDIT: Taken Ytube vid down out as it is no doubt a one off and I don't want anyone to think this happens a lot if they search!
EDIT: Fresh replacement already on it's way directly from Hudson.
Well get it sorted, no problems
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
Probably something simple, I'm sure it will be fixed very quickly
Tate FX
www.TateFX.co.uk
Instagram
I put this post up thinking I might have been doing something wrong! You never know...
Anyway, what I can say is that when I opened the pedal up to see if I could see any signs of anything loose, it is gloriously well put together. Very neat and tidy.
No doubt it's just bad luck.
I have a replacement on its way and they will investigate the issues with potentially faulty one.
Cheers!
JM build | Pedalboard plans
I have some more Hudson stuff coming tomorrow as well including some Sidecars, which are also becoming difficult to get your hands on!
