Have decided to use my AV52 tele primarily for alternate tunings (incl stones stuff) and slide.
Ive always thought this guitar manages a lower action than I’d expect with the 7.25 radius but it’s a bit buzzy and fragile when I take a slide to it.
My first step is to order a set of 11s (currently strung with 10s) which should help.
Looking at string height at the bridge and bearing in mind it won’t be exclusively for slide, do I
a) maintain the radius but raise the string heights at all saddles
b) maintain the current string height in the middle but level off the outer saddles to flatten the radius
c) flatten the radius and raise the string heights, including middle saddle?
Bearing in mind I still want to play open g stones riffs etc, what’s the best compromise for a slide friendly setup?
cheers
In terms of overall action and string gauge it depends entirely on how much you intend to practice. You don’t need a high action or heavy strings to play slide if your technique is on point.
i also prefer the radius to be maintained.
http://www.hotroxuk.com/concave-brass-slide.html?utm_source=GoogleBase&utm_medium=organic&gclid=Cj0KCQjwpsLkBRDpARIsAKoYI8z8tjdZg16A23o0fqX0gnnDg5Jx0Kh_9J6aKnGGYSU5bCPQABunp0oaAl8zEALw_wcB
Costs less than a pro setup (I’ll need one if I mess up the current setup!).
Restrung with 11s which helped straight away but didn’t quite achieve rattle free slide.
Tried the Dunlop Slide converter. Work of the devil I’m afraid. Despite stating “works on any guitar” the straight bar didn’t sit well on my 7.25 frets. Horrible metal to metal design that easily scores the frets and fretboard. Slips off fret during play. Sets strings far too high even with sleeve off.
So have raised the strings around 0.6mm each at saddles, trying to maintain the radius. Now we’re in business. String height above 12th fret now around 2.6mm and 2.2mm at high E. Still playable and seems a reasonable compromise.
FWIW Derek Trucks signature slide is fantastic.
All I need now is time to practice...!
