Hi Guys
I’m just a home player and I play mainly clean with a bit of reverb which the Roland Blues Cube Hot does very nicely at bedroom volume.
I want to build a small bedroom pedal board for when I want to do something a little different.
The main tones I’d be trying to get close to are a kind of clean but driven lead tone if that makes sense (think John Mayer in where the light is) and also to try and get close to a kind of Gary Moore / Still got the Blues tone.
I’m guessing a Tubescreamer mini will be a good shout for that clean-ish driven lead tone, but how would I go about trying to get close to that Gary Moore tone (without buying a Les Paul and a Marshall stack?!)
All advice appreciated
Thanks
Suhr Riot
Bogner Red
Amptweaker Tight Rock Jnr
Friedman BE
Thorpy Gunshot
etc.
JM build | Pedalboard plans
This is a picture, its not up to date as my amp has reverb now so the reverb was replaced with a low gain drive:
https://i.imgur.com/qng1XQI.jpg
It's probably worth reading the manual to see what you can alter about the Blues Cube's tone- much of the sales blurb on the Roland website is about how it's supposed to mimic the sound of overdriven valve amps.
I was thinking more of the John Mayer dirty-clean sound really, but it pretty much depends on what your amp can do, and which sounds you need to be able to switch quickly between (which might be none).
