SPEAKER IMPEDENCE CALCULATOR
It does have two mixers however which allow you to change the level of a patch, or to have spill-over between patches. The ES5 only has one mixer though as I found out recently when I wanted to do both of these things at once. Kind of annoying.
I think for your use-case the GigRig G2 might be a better bet. I'm not sure if the Musicomlabs ones offer the same functionality, maybe someone could chime in on that.
Don't want to spend G2 money.
The main one is an ancient DOD Phasor
Doesn't sound like any other I've found. Very very thick and chewy sound.
Edit: checked and it was just patch level.
