Manchester Guitar techs clear nitro is the best I’ve used, Steve is an active member here as well.
cheers
TC
That said you can mix & match paint types but it is quite easy to get into a mess doing it whether immediately or down the line.
Ah right, if it was me I'd go stain or paint/lacquer all the way to be sure it's compatible & sticks well. But I've seen posts here & there about oil + lacquer so it must work as such, though I've not tried it nor really sure what benefit there is to it. The final sheen is down to the lacquer, and that's what you're touching, so the oil seems redundant - but I might well be missing some reason people do it.
