How can I stop acoustics hanging on the wall resonating with electric amps in the same room?
ToneControlToneControl Frets: 5353
Currently, my music room is partitioned, so the acoustics don't ring out when I play electric
But if I remove the partitions, or further increase my acoustic to electric ratio, I'll need to hang acoustics on the wall in the same space as my amps
Is there a best way to do this?
I was thinking maybe something like a velcro strap around the fingerboard, like those ones people use for doing tapping on electrics
  • FuengiFuengi Frets: 988
    I'd imagine that some sort of soft cloth stuffed between the strings and fret board will suffice?
  • guitarfishbayguitarfishbay Frets: 7516
    Gruv Gear Fret Wrap
  • thermionicthermionic Frets: 5539
    Mike them up to add a ghostly ambience to your electric guitar recordings. Plus the wood will get artificially played in and they will sound better.
  • octatonicoctatonic Frets: 21326
    edited April 16
    Fret wraps work fairly well, but if I wind an amp up loud I can still hear the acoustic guitars humming a bit.
    At that point I either put the guitars in a case or turn the amp down.
  • WhistlerWhistler Frets: 44
    edited April 16
    Fret wraps cover just one spot. I would be inclined to slide a duster between the fretboard and strings to damp them over as much of the length of the fretboard as you can.
  • VimFuegoVimFuego Frets: 7074
    as everyone has said, damping the strings would be the obvious 1st port of call, however I wonder if it's a frequency thing as well. I've noticed that my acoustic rings/vibrates a bit when I play my fiddle, which isn't especially loud but is quite high pitched.
  • PhiltrePhiltre Frets: 1279
    I wedge a used pair of underpants between the strings. I can lend them to you, if you like.
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom · Share on Facebook Share on Twitter
  • ToneControlToneControl Frets: 5353
    Does that come with extra mojo?
    1reaction image LOL 0reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
    the strings or the soundboard?
    It can be sympathetic vibration.
    You can observe this on a guitar. Play the note of an open string on another string and that string will vibrate.
    You could detune the acoustics a tad so they don't resonate. If that fails, I'm afraid the only solution is the wedged underpants.
    Well they make up a system so kinda both.
    I have one guitar that has a resonant frequency around G and it tweaks anytime I play a loud G though an amp.
    That guitar lives in its case now.
  • ICBMICBM Frets: 38156
    Fold up a duster neatly and put it between the strings and the top of the guitar between the soundhole and the bridge. That will also stop that bit getting dusty, which is where it's hard to clean normally.
    Just be careful if it's a nitro finish - the dye from cloths can leach into it. If that's a possibility then I'm afraid the white cotton underpants may be the only solution...
    what about French polish?
    I'd be careful about that too. Probably best to stick to putting it between the strings and the fingerboard.
    For what it's worth, unless you're actually recording or something where it becomes a real problem, you're actually better to let the acoustics ring - it makes them sound better. This isn't a joke... it even affects electric guitars and basses. I've lost count of the number of guitars that have come into the shop to be sold - usually having been kept in a case - and they sound dead and un-resonant, even with new strings. But after they've been hanging on the shop walls for a few weeks with all the noise from amps being tried, they 'magically' sound better - sometimes really amazingly so.
    Softer and more fragile- be more careful.
