I am experimenting a little bit with my new HX stomp and stereo sound before I put it on my board ...
I have two (or sometimes three) effect chains - mostly reverbs+delays - all in stereo - one is strymon mobious+timeline+bigsky, the second chain is boss dd-500+rv-500 and the third is a single volante ...
I would like to be able to use them in stereo in the fx loop of the HX stomp - one chain in a time - not all at the same time ...
There are not many budget friendly options for switching stereo loops - after searching for a quite long on the internet I have narrowed my choices down to Lehle D.Loop SGoS (easy to connect into my setup, but only 2 stereo chains) and the second candidate would be Joyo PXL Live (which is basically Harley Benton FXL8 Pro
@Thomann.de) - based on the documentation it seems that the PXL Live could (hopefully) be setup as 2 chains x 4 effects configurations - and I hope to use these two chains to feed the left+right channels of my stereo signal - this would enable me to have up to 4 chains of effects - however it would be quite complicated not only to wire it but also to control it ...
The question is - have I missed some more obvious and simpler option ?
Thank you for any ideas ...
