I've just nearly finished a tele type guitar kit that i had for xmas, and tbh although its not perfect i'm quite pleased with the outcome - it seems to stay in tune and the action doesnt seem bad (although a good setup would help).
Anyways the only thing i have left to do is wire up the electrics on the control plate which has one of those 3 way 7 lug import switches but i have a spare 5 way switch which i fancy dropping in for a couple of extra options (series/parallel?).
Does anyone know any wiring diagrams for this type of switch that would work on a tele?
Or a Superswitch, but I think (could be wrong here) they're a struggle to fit into a Tele control cavity.
Should be:
Pos 1 - neck with less bottom (2uf cap)
Pos 2 - neck/bridge both out of phase
Pos 3,4,5 - as a normal 3 way.
Soldering iron at the ready!
