I had a head which I did a few mods to, including bypassing the standby switch altogether so it did nothing, which meant that the guy who helped us set up/ tear down at gigs could carry on using it like before and I didn't need to keep telling him not to
A relatively common issue is that the FX loop bypass switch on the back panel gets a bit dirty inside which causes signal dropouts/ crackles that people often take to be a valve failing or some major issue. So if you get crackles, low volume or occasional dropouts, before you take it to a tech try flicking the FX loop bypass switch back and forward a few times to see if that fixes it.
Bandcamp
Spotify, Apple et al
Pedals are very player/ guitar dependant, but the best I found with it were the Bognor Burnley, Timmy, Proco Rat, & basically any clean-ish boost. Smallsound/Bigsound Fuck Overdrive was great too, but I don't know how easy it is to get hold of them any more.
Bandcamp
2nd Set, swapped out the egnator goldsmith for a Boss OD3 and a TC spark booster, and those 2 as well as the rat and a Les Paul sounded generally great to me anyway!
Its definitely a very different amp to what I'm used to but I really liked it in the main, and found I was using the volume on the guitar far more than I usually do.
I don't how people can crank these amps tho. Drummer is a loud one, and I don't think I had the Master volume over a quarter, and that was on the 22watt setting..
That Mini Beatle sounds superb too...
