That's likely to be too much of a mismatch.
Why not just use both amps? Carlsbro (4 ohm) to sub, Sound City (8 ohm) to main cab. Problem solved.
So you are using a valve amp for bass? Too much up there for this old brain. Bottom line for valve amps..
SIZE is everything. Well the size of the signal that is. You can run a valve amp quite safely as a rule with a 50% "mismatch"* either way (but lower is a bit safer than higher) SO LONG as you are not driving the bllx off it. Many amps will tolerate even that but some won't!
But you seem to be saying you will set the amp to 4Ohms and run 2 eights in parallel? Happy amp if so.
Transistor amps will blow if the load is even fractionally lower than rated and even some cheaper ones though rated for 4R can still fail and NEVER connect any kind of transformer to a transistor amp. It is often said sstate amps can be run open circuit. In theory yes. In practice don't do it especially if again driving the bllx sort of thing..
*We don't of course "match" audio kit no, not even valves and speaker but that is a whole other can of worms.
Dave.
