SOLD. PEAVEY CLASSIC 20 MH - 20 Watt Mini Valve Head
SOLD
Here's a superb little all valve head from Peavey.
Based on their well established Classic range, this is the 20 watt MH (mini head). It features 2 channels and a boost switch, giving a wide range of tones covering everything from crystal cleans through to medium to high gain - the tweed finish might hint at a more vintage voicing but this amp really is very versatile. You get a very dynamic eq section, plus a great input and output gain stage which allows you to tailor your gain for more of a vintage or modern setting.
On the back, there are connections galore with your standard speaker out (with switchable ohms), effects loop (send/receive), footswitch sockets, as well as sockets for headphones and an XLR out for recording. Also on the back you'll see the output can be switched from 20 to 5 to 1 watt for even more versatility.
There's not a lot this amp won't do - and it looks so cool!
As if that's not enough, it comes in pretty much mint condition, including the footswitch for channel and boost, and the instruction disc. It has all the original packaging, even the outer shipping box (not pictured) so can be well protected if you need it posting. It's in perfect working order having only been bought 6 months ago from Absolute Music, and you'll see the valve condition lamps glowing a healthy shade of green!
Grab an all valve Classic, like new for a great price... £300 (collected from Nottingham or posted at cost)
