Hmm, I doubt there will be a blonde 1x12 until and unless there is an Artist 15 blonde head?
Now, when the ArtiSAN combos came out there was quite a clamour for a head version (especially I think for the A30 which seems Araldited to the floor!) so then cabs followed.
The head versions of the HT range were also after the combos. Whether that was due to "pester power" I have no idea but I suspect so.
Mind you, Blackstar have a pretty big range of products now and you "can't please......" or you go broke!
Dave.
No there isn't an extension cab for it.
There is also something to consider when using it with another cab - the outlets on the back are 1 x 16ohm, 1 x 8ohm or 2 x 16 ohm. The factory fit is an 8ohm speaker so unless you change that, you can't run an extension cab without risk of damaging the output transformer.
Yes, I know... annoying.
I thought it was 16ohm? Taken from the manual...
I've been using it with the 16ohm PPC112...is it going to explode next time I try it?!
Speaker Outputs The output marked ‘1x16 Ohm’ is for the connection of a single 16 Ohm extension speaker cabinet (or the internal loudspeaker of the Artist 15 combo). The outputs marked ‘1x8 Ohm or 2x16 Ohm’ are for the connection of either a single 8 Ohm extension cabinet or two 16 Ohm cabinets. Also, the internal loudspeaker of the Artist 15 combo can be plugged in here if it is used with a 16 Ohm extension cabinet. See table below.As you were, it is a 16ohm.
Sorry!
