Pro Junior Issue
chrisj1602chrisj1602 Frets: 3965
I’ve recently picked up a Pro Junior III, it sounds nice at the lowish volumes I’ve played it at, but if I try to get to around 5 or 6 on the volume, it makes the most horrible howl, almost like feedback, but without any input. Any ideas what this could be? Is it valve swap time or something worse...?
  • ICBMICBM Frets: 72308
    Sounds like a microphonic valve. Try replacing the first preamp valve - nearest the input jack. If you don't have any spares, simply swap the two preamp valves - there's a good chance that the other one won't be as bad, and the bad one won't be as much of a problem as the phase inverter.
  • chrisj1602chrisj1602 Frets: 3965
    Thank you very much, I will try that.
