FS - Victory V40 Duchess Deluxe head with matching V212VC 2X12 Cab, with covers & footswitch.
jimkehoejimkehoe Frets: 145
Victory V40 Duchess Deluxe head & Victory V212VC 2X12 Cab, covers & foot-switch
Superb head and cab combination suitable for quiet to stadium, clean to filthy with superb tremolo and reverb.
This is in excellent condition - careful home use only complete with fitted covers and foot-switch.
Rarely available used, particularly in this condition.
Collection only from near to Dorking in Surrey for cash. £1500
https://i.imgur.com/6hgSkcX.jpg
https://i.imgur.com/j6gB8Qt.jpg
https://i.imgur.com/ZwKyu06.jpg
https://i.imgur.com/xniJqRR.jpg
https://i.imgur.com/oqtm23m.jpg
https://i.imgur.com/AN5ldQx.jpg
https://i.imgur.com/6mWRneh.jpg
https://i.imgur.com/lDNxqb6.jpg
https://i.imgur.com/XthUz4n.jpg
https://i.imgur.com/bN0EjHi.jpg
V40 Deluxe lives up to its name in stunning cream vinyl over traditional wooden cabinets with leather corners and handle for a modern-boutique look. You can expect classic American cleans through to pushed tweedy grit and on to driven British blues-rock. Choose between 1x12 combo or head & cab.
This is one for the 'feel' players: a boutique-standard tone machine for home, studio and stage.
"Magnificent ’60s-style Fender and Marshall tones from a single channel. Enough power and headroom for most gigs. Fine workmanship. Gorgeous reverb and tremolo. Fair price."
Single Channel & Voice Switch
Go from vintage-style Californian tones with single coils, through to a driven mid-’60s British drive all in one channel. Voice II strengthens the midrange at the input for more punch and cut. Compared with V40 The Duchess, V40 Deluxe has slightly more brightness and 'air' overall; a step or two away from mid-Atlantic Duchess towards Californian Deluxe.
Mid Kick:
This works in conjunction with the Middle pot to boost midrange frequencies in the EQ section. The more you push the Middle pot, the more it pushes overdriven sounds, especially with humbuckers. Overall you'll find slightly more overdrive and compression at maximum gain than in the Compact Series V40 The Duchess.
Valve-Driven Spring Reverb:
V40 Deluxe benefits from a valve-driven-and-recovered long-tank spring reverb, for authentic, vintage-style ’verb. We've also included a Tone pot on the reverb that enables you to go from smooth, dark ambience to much more bright and 'springy' sounds. The reverb is also footswitchable on and off.
Valve-Driven Tremolo:
Tremolo was one of the first ever guitar effects that's been put to stunning use in everything from blues, rock'n'roll, country, rock, Americana, pop and much more. Given V40 The Deluxe's vintage leanings, it was a shoe-in for inclusion here. Try it with a ton of reverb and wonder how you ever lived without it!
Low Power Mode:
You'll find a switch on the rear panel offering a low-power mode for around 7 watts. This works brilliantly for home and studio use, not to mention for those of you on quiet stages with in-ears. Or… just max out the amp and bask in that extra low-volume drive and incredible compression.
Series Effects Loop:
The hard-bypassable effects loop enables you to use delays, reverbs etc after the preamp section of the amp to keep them clean sounding. V40 Deluxe uses a post-phase-inverter master volume, so if they aren't as clear as you like, try lowering the mix/output of the pedal, especially as you turn the amp master up.
V40 Deluxe key features & specification:
Format:  Single-channel head
Power: 42 Watts high power / 7 watts low power
Valves: 2 x 12AX7, 2 x 12AT7, 2 x 6L6
Size (mm): Head - 485(w) x 260(h) x 255(d) inc. leather corners, feet and handle.
Weight: 12.5kg / 27.5lbs
  • Footswitchable spring reverb with tone control
  • Output bias tremolo
  • Mid Kick switch
  • Voice I & II switch
  • Series effects loop with hard bypass
  • External bias test points and adjustment
  • Dual-button footswitch for Tremolo & Reverb ON/OFF
  • Slip cover included
V212-VCD
2 x 12 Compact Vertical Extension Speaker Cabinet: Celestion G12M-65 Creamback
SPEAKER CHARACTERISTICS: The G12M-65 Creamback is less sensitive/efficient (97dB) than the Vintage 30 and also the H-75 Creamback, using a medium-magnet (35 ounce) 12-inch driver. Celestion regard it as a 'more powerful Greenback' and that is the perfect description. Expect that classic, 'woody' tone and feel to add colour to your medium gain sounds, with a little speaker breakup to boot. Using two together in this cab increases the bottom end strength and power handling, with plenty of '3D', room-filling projection from front and back. There is so much character in this cabinet for classic low/medium gain tones at any volume.
 It works perfectly with the V40 family's unique dynamic and feel.
Power handling: 130 watts
Impedance: 16-ohms
Speakers: 2 x Celestion G12M-65 Creamback
Size (mm): 485(w) x 700(h) x 295(d)
Weight: 47.4lbs/21.5kg
Colour: Cream with tan leather corners and handle, includes slip cover
