Here's a bit of helix feedback. Rehearsal - the first with a helix using a set of snapshots based around the jumped marshall. into an active monitor. High and low cuts in the usual places (100 ish and about 10).
Really impressive - standing in the middle of the room between the two guitars and there was no way that I could tell that one was better than the other (my mate playing an expensive fender job). The lead sound goosed by the modeled sd1 was nice - gainy but could be cleaned up - rhythm sounds thick and very marshally.
happy. some tweaking to be done - I've got 4 snapshots which is probably one too many and need to get better at changing the delay settings on the fly
however I can now sell my main rig and 2 x 12 cab. To me there was no significant difference between my old rig and the new in terms of the quality of the experience. sounds were different obvs but one not markedly better than the other.
just for the record as they say
I haven't tried comparing the two rigs in the same room with the band - I'm just going for sounds that work
I'd say keep your 2x12" - I went FRFR, but then came back to the cab with a Seymour Duncan Powerstage 170, which (in my opinion) is the option that gets the best out of the Helix by far.
Personally I play with an amp and HX effects. As hard as I’ve tried I just can’t get past the lack of thump and what an amp brings to the sound.
The issue that all users of modelling gear have to resolve is if they are happy with the sound of a mic'd up cab, or whether they want to hear amp-in-the-room sound. Neither is right or wrong, it's a personal choice.
R.
Eqd Speaker Cranker clone
You either use a real cab and get amp-in-the-room sound, or you have some sort of speaker emulation and use a FRFR (inc. Foh). Yes, you can do both with a split, in which case you're choosing that you want to hear amp-in-the-room on stage.
R.
Collision rock band
