Always a compromise.
If the FX output is from a valve it might be a highish source impedance so you would not want to load that lower than 100k.
Trouble is that makes the output resistance of the box high and can lead to HF loss (aka "tone suck"!) so keep the output lead as short as possible, say 2mtrs max.
But most FX outs are an op amp these days and so go for 10k log and have cables pretty much as long as you like!
And! Fit two jack in parallel so that you have a "clean feed" from the FX out. Costs beans, can be handy.
Dave.
Simply give it two 'input' jacks, connected to each other tip-tip and ground-ground.
@ecc83 any predictions on how one of these http://www.ehx.com/products/signal-pad would work in the FX loop of a HT-50?
Would a buffered pedal into the front of the amp suffice?
Yes - no need for it if you'll never use that, I just thought it was a neat idea that I hadn't come across on any of these boxes yet.
Wish I 'adn't said nuffin now!
The extra plleled jack is just one of my foibles! I tend to think that I might need a test feed or a recording output.
I would draw it up and post an attachment but I cannot see how here.
IC, never had a dirty contact problem. You must get some real ***t to fix! What I HAVE had is a couple of A30s which had higher than normal hum levels when the VC was advanced sans jack. You guessed it! The input jack was not shorting. This turned out to be a damaged socket which had obviously been strained with a lead and the contact bent.
Bit of a fiddle to fix because the 6dB pad resistors are all built around the two sockets..But! We can't have £1000+ amps out of specc' can we? Even if the owner never noticed!
Dave.
Also a very common problem with any amp with PCB-mounted jacks - and/or if they don't crack the pin joints!
"Also a very common problem with any amp with PCB-mounted jacks - and/or if they don't crack the pin joints!"
That should not happen if the jacks are well secured to the panel and the soldering is good. I have certainly never had a problem in any amp or pedal with this.
I HAVE had the issue with USB ports on the front of PCs and the DIN and USB port on my Evolution MIDI keyboard.
There are of course millions of jack contacts in use (and dormant for months) in jack patch bays. I spend some 2/3rds of my forum time at music recording places and have not read of any such problems. I reckon the jack makers save all the ***T for geetarists!
Dave.
