Hi guys
So I want to record acoustic guitar into pro tools through my 11r. The way I see it, I have two options: I can either buy a soundhole pickup and plug into 11r as you would normally with an electric or I can just buy a mic and connect it through the mic input on the 11r.
Which option do you think would be the best in order to get a natural sounding acoustic track (to be recorded both in isolation and in a mix with other instruments)?
Which equipment would you suggest in either case?
Thanks in advance for your opinions.
____
"You don't know what you've got till the whole thing's gone.
The days are dark and the road is long."
A mic will almost certainly give a better sound than a pickup when recording (pickups are handy live but never sound as good).
If you're using the mic pre on the 11r (I'm fairly sure it has phantom power) you just need to experiment with putting a mic in front of the acoustic. The simple low cost way is to grab a condenser mic (probably SDC but you would get useable results with an LDC vocal type mic and point it at the higher end of the neck.
How much you are willing to spend will decide the best options mic wise. There are a lot of cheap and cheerful made in china SDC's from firms like sE or Rhode that will sound great for very little outlay.
I will investigate on mics - do you think £50 to £70 would buy me a decent mic?
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
https://soundcloud.com/fnpt/acoustic-test2
https://soundcloud.com/fnpt/acoustictest
