OK so here is the setup.
My new band have access to unlimited free rehearsal time in the evening in a small office type room. We have no storage there so we have to bring and take what we use and limited car space.
So far we've just been playing out of amps, but the small and non acoustic nature of the room means it's very loud and very washy. We did a first rehearsal with a singer last night using our PA. This kind of worked, but had a few limitations.
Shifting and setting up the PA and taking it down again is time and space consuming
The small room means the PA really wants to feed back and it get's crazy loud in the room
So we need to think of another solution.
The two things we've thought about are buying some wedge monitors and using them in rehearsal, or buying a bigger mixer and going towards some kind of IEM based solution.
As well as rehearsal we probably need to do one or other of these things before we start gigging anyway.
If I went the IEM route I'd probably not bring my amp to rehearsal and use something like a Tech21 Blonde pedal into the desk.
Thoughts?
They get used a lot by school bands as they help keep the overall volume down.Or he could buy dampening thingies for his drums* which are relatvely cheap and cut volume down a fair bit, although feel and tone suffer. On the other hand if you can't play through your amp...
* like little round rubber mats for on the skins
I really can't recommend the Flats highly enough. They probably won't satisfy a big-hitting drummer who likes a full-sounding rock kit (much in the same way a little 15W amp won't satisfy those guitarists who like a 100W amp... cough ), but for everything else they're fine. They really are good for a non-full-band gig situation too - we used them for acoustic-ish gigs to keep the level down.
I made some for my kids' drum kit from Ikea table mats . (The coloured round foam plastic ones.)
If he has an electronic drum kit then it might be relatively easy to bring to rehearsal depending upon which one it is. It would be a compromise but then that's in the nature of these things. Maybe plan in a Soundcheck Rehearsal prior to your first full gig where you find a bigger room and set up as if you were doing a gig and sort out any level or other issues that haven't been picked up.
I have done a couple of rehearsals in someone's kitchen. Okay, biggish kitchen but electronic drum kit, practice amps and vocals through another practice amp. It wasn't rehearsal as in simulating a gig but for working out arrangements absolutely fine and never far from a cup of tea.
Apart from the weight/space benefits the consistent IEM mix irrespective of the room/gig means that they are the modern solution. As far as cost, you will pay as much or more for a comparable wedges solution, anything cheaper will be a feedback nightmare.
Otherwise I agree with ICBM, just turn down and train the drummist to use lighter sticks/touch or his electric kit. No reason for the band to suffer the save his feelings and anyway you don't insist on a 100w stack at full chat for your feeling and tone do you?
@Monquixote if you go down the pedal into board route, and need/want to try any of my gear, drop me a line.
Also is there any way you could run a cab/second cab from your amp* and use that as a make-shift monitor (even temporarily).
*I know my DSL has a line-out for DI-ing and also has an extra out for a second cab, not sure about your amp.
http://jamhub.com/what/index.html
http://www.dv247.com/studio-equipment/jamhub-bedroom--70525
@monquixote - A similar concept to the jamhub and just about to be released by Roland - HS-5 Session Mixer
https://www.youtube.com/watch?v=ULjTz_91z8A
