There's a lot in there that means if you're after the quintessential quack of positions 2&4 from a strat, you'll not get that perfectly with the PRS.
However, PRS clean sounds still sound good, just different.
Can't remember if the CU22 has a coil tap, but if it does, that might help a little. A PRS isn't 'designed' for overdrive really, and has some great tones in it, as does a strat.
Hope that helps
My music:- https://soundcloud.com/hubobulous
To me a 22 fret, double cutaway, set-neck PRS is (be that a Custom, a McCarty, or other more upmarket variants) is the nearest to a Les Paul that I can cope with, as someone who only used to play a Strat.
Though (as @Monquixote said) they are something of a half-way house between the two, the 22 fret models are much fatter sounding than the 24 fret versions. The thicker bodied ones (McCarty/DGT, etc) are fatter sounding still.
Its true that their single-coil tones aren't as 'snappy' as a Strat - the wood combination, set-neck construction, scale length and bridge/trem design all play a part in this - but they are a real Swiss Army Knife. A Strat and a Les Paul can't convincingly cover each other's territory - but within the context of a band mix, a PRS can. Yes it may be a compromise but it is a highly musical one, which is superbly ergonomic.
The 'they are for dentists' brigade will try to tell you they are all bling and no substance; they are not. They are brilliantly designed and beautifully built guitars. Whether they are for you - only you can really judge.
Check out youtube for plenty of PRS vids, Johnny Hilland and Brent Mason are both big advocates of 'clean' PRS sounds. The Brent Mason sig guitar looks(sounds) very nice too......My McCarty gets very nice Hendrix like sounds on the coil tap settings
