Feedback can be found here http://www.thefretboard.co.uk/discussion/comment/908933#Comment_908933
In eq terms all I can advise is to eq the amp while listening on the in ears rather than before putting them in (if you are not already doing that. ..)
I've had similar issues...
Most importantly, make sure you're using good quality drivers in your ears. I know this sounds obvious, but I went from using the standard DB Tech ones that came with my monitor system (MEI1000) to some Shure drivers (forget the exact model, cost about £100), and the difference was remarkable!
At first I found to get the right sound for my IEM's, id have to butcher what was going out front; obviously counter-productive. I found adding some low mids (around 250-450hz) fattened out the sound in my ears and it 'felt' better, but obviously sounded rather muddy FOH. Scrap that idea!
I have started dialling in the tone on my amp with my IEM's in, which made a little difference. For me personally, I found reverb to be the cure! Depending on the desk you're using, try sending more reverb to your IEM mix only, the difference is surprising! Like someone else pointed out, the sound of your guitar in your ears is so much dryer than you're used to and can be really off-putting!
Just my two penneth anyway, hope this helps!
I've recently acquired a Sequis Motherload Elemental as well, which is truly brilliant. Incredibly realistic - also passive and transformer-balanced... it draws all the power it needs from the speaker input.
da dum de dum, da dum de dum, da dum de dah dah da dum de dum.
The light at the end of the tunnel is a dead end with a brightly lighted sign reading "Detour" pointing back the way you came.
Simply put, you sound like a bit of a douche, don't stick around too long
Gone.
