If so, how do you hold your plectrum... is it tight in your fingers or do you hold it more loose, so that is gives with the string when you are playing.
I play traditionally using a combination of picking, hammer-on and pull-offs to get any sort of speed, but would like to be faster with my picking but without making the notes aggresive i.e. like a Pat Metheny style.
Is there some trick to getting the speed up but keeping the warmth and a lightness of touch in my playing?
IME a rigid plectrum gives you more control; faster picking is achieved by exercising and trying not to tense up the wrist hand & finger muscles while you're doing it. Try picking semiquavers at n bpm where n is some comfortable value that you can keep up without falling over yourself. Push it to n+2, n+4 as far as n+x bpm (where x is the highest possible increment that you can achieve for a short time) then relax back to n+(x/2) bpm. next day start with new n = yesterday's n+(x/2) and repeat. I call it the stretch & relax technique: you may wish to start with repeatedly picking the same note, then as you get better try runs of notes up/down the same string, then try scale or arpeggio fragments.
I think Pat Metheney loses the "aggression" by rolling back the tone pot which tends to remove the transients
