Do you accept that to have guitar with a nitro finish means a pay-off between optimum tonal quality and a gradually buggering finish?
My white Les Paul has suffered steady degradation to its white nitro finish from new in 2007. It simply sits on its stand (carefully insulated so the black rubber doesn't leech into finish) and is just getting worse and worse... Is un-giged and in a non smoking environ - in fact stands in my dining room! And no - I do not have dirty sweaty hands!
Would you accept this as part of the historic relic chic ethos?? The guitar sounds epic though...
<Vintage BOSS Upgrades>
Nitro cellulose when fresh, moves with the wood because it is a "soft" finish. As it ages it gradually loses its plasticity and gets more brittle and hence lacquer checking. Temperature and humidity variations affect the rate it checks; the bigger the variations, the faster it will check. The discolouration ie yellowing is due to oxygen reacting with some of the polymers, physics and not mnuch you can do about it other than store it in a vacuum. You'll always notice these effects more on a white guitar.
The ageing of Nitro is radically affected by the organic acids in sweat and hence the neck and "under your arm" areas discolour and age more rapidly. No matter how much you think you don't sweat .. at a molecular level and enough to accelerate Nitro ageing ... you do
I'm looking forward to my junior special finish to start wearing.
My Arctic White '94 American Standard Strat is distinctly cream-coloured, even though it hasn't been kept in a smokey environment.
Older Gibson finishes seem to check more finely. Newer ones seem to actually 'crack'. I presume the composition of the finish has changed. I understand from an environmental point of view, nitro is something of a problem - so the stuff being sprayed now is different from the older stuff.
I suspect the other issue is that the woods used in a modern Gibson move around a fair bit more than they did in older ones.
Cost....
Gibson use modern day nitro finishes which have plasticisers to prevent degradation, hence why you have to buy older formula nitro-cellulose from suppliers like Rothko and Frost to obtain that chequered knackered look.
So whilst I agree nitro does age and look shabby far quicker than poly, a 2007 Gibson that is cared for and looked after should still look good. My 2000 era Gibson's still look new despite being gigged.
Sorry I'm confused, what are you suggesting posting pics on a gibson page to be immediately removed or post pics on here?
