This is probably blasphemy but...
I notice the Green Ringer uses 2 NPN and one PNP silicons. How about just reversing that order and running everything positive ground?
Pedal PSU jacks are the bloody silly wrong way round anyway!
Dave.
Is it basically connecting the two effects to the same input/outputs etc?
Thanks guys!!
The effect in/out go to the PCBs as normal.
The signal in out go as follows: In jack to stomp A in (as normal). Stomp A out (which would normally go to the out jack) goes to stomp B in. Stomp B out goes to the output jack as normal.
If you want them in parallel you get into buffers and mixers. Which won't work with a fuzz face for a start. If you want an order switcher it can be done, but it'll add complexity. Best to decide which order they sound best in and wire them that way.
