Jim Dunlop Strap Locks
gubblegubble Frets: 1746
Hi Guys
The strap which i use with a set of Jim Dunlop strap locks has seen better days and needs replacing.
Is it possible to change straps? there's a retaining clip on there which i'm assuming i can remove however is it reusable?
It's been probably 13 years or so since i put them on there so can't 100% remember how easy it was to get on
chris
  • TTonyTTony Frets: 27452
    I've always found them a real pita to get on the strap.
    Buy another set for the new strap, and then you've always got a spare strap ready fitted with the locks ...
  • gubblegubble Frets: 1746
    I would do that however i'm a bit broke at the minute and the origional strap is genuinley falling to bits.
  • DrBobDrBob Frets: 3005
    I've got s spare set of the bits that go on the strap. You can have them if you like ?
    Ohhhh yes please, please let me know how much you'd like for them
    Only your postal addy and a promise that when you speak of me you speak well ;-)
  • FelineGuitarsFelineGuitars Frets: 11590
    The cir-clip can be opened and the assembly can be shifted to your new strap no problem
    However do keep an eye out for wear on the mechanism as like all things they can and do wear out slowly
    The only times I've ever had difficulty fitting them is if the strap is particularly thick at the end (I've been known to squish  strap end in a vice to temporarily make it easier to fit the locking gubbins.
    However it is usually better if you have a 10mm hole punch/leather punch to make a neat hole in the strap end. (I usually carefully position this to only just come to the bottom of the old hole and also remove some of the slit that leads to the hole resulting in a more secure fitting for the future.
