3-Knob BK Butler Tube Driver (TubeWorks) Power
Good Morning Forum-Folks!
I have a 3-Knob (steady now) BK Butler TubeDriver. Does anybody know whether I can put 18v into it (It says 9v but I'm feeling greedy) to give it a bit of a kick? Only reason I ask is that the 18v outputs on my board power supply aren't really being used (apart from powering an Ethos TLE) and I could put one of them into the TubeDriver. Obviously I don't want to kill the pedal as its getting on now.
Any help would be greatly appreciated.
  • swlabrswlabr Frets: 29
    Hi
    Seems to go fine with 9v power supplies between 200 and 300mA.
    Heard some using them on 12v but not on 18.
  • @swlabr Thanks for the info. If I'm feeling brave I'll give it a go later.
    Regards
    You have ICs in the Tube Driver as well as the Valve, i wouldn't chance 18v unless someone more knowledgeable like @ICBM thinks it is safe.  Better late than fried !
  • @ChrisMusic... That is true. Don't want to fry it. When I said I'd try it... I meant try at 12v. ;)
