So...
I would like to buy some tubes for my Hot Rod Deluxe II but I have a few questions!
Hot Rod Deluxe II is 2 x 6L6's in the power section and 3 x 12AX7's in the preamp section as far as I'm aware.
I assume the amp will need biasing for the power tubes but not the preamp. Is this right? Is it best just to get the lot done in one go? I reckon so on this go since they've not been done in a while but what about in future? Any tube recommendations for a Hot Rod Deluxe? What's a JJ? What's a groove tube? What's a Sovtek?
Also, I've noticed the power light on the HRD keeps going dim and lighting back up again. The amp sounds absolutely fine. No issues with that, just the stand by light flickering between dim and bright on occasion. Should I be concerned? Is my amp going to explode mid gig?!
Advice and help appreciated!
