I think it's DSP chips more than just digital. Probably okay with a basic digital delay with a pt2399 but anything with full on micro processors are more fussy. Sometimes Tap tempo's seem to cause noise as well for some reason.
I have isolated power now, for no reason other than it was cheap (hHarley Benton Powerplant Jr) and I notice no difference in noise to before (a compressor, tuner, wah, drive, distortion, fuzz, phaser and digital chorus).
You chained 8 pedals in 1 socket?
Some pedals won't play ball, I'm sure, but I've not had any issues. I'm not unfussy when it comes to noise, either, I use quite a bit of gain for some serious crunch.
There is some Internet wisdom that's a bit... Not true.
All the above ran from a single one spot psu. I ditched it for a proper supply and keep that as a backup, just because I now don't need to worry if I do get a fussy pedal - I just stick it in a different socket.
There's a fair few EHX pedals that don't play well with others (some because of their 'positive ground' wiring, apparently - others just because they're weird); I had to let go of a Bass Metaphors and a Small Clone because they just wouldn't work on my board without humming.
The Double Muff I had issues with as well, but apparently that's a buffering issue rather than a power one.
