I am in the process of putting together two Tele's at the moment, one Pink Paisley, one Thinline kit from GSP.
I decided to use the GSP neck from the thinline kit on the Pink Paisley (the birdseye/birdseye is amazing, much much better than the Allparts jobby I was going to use) and Grahame is making me another birdseye/birdseye that I will then use on the thinline.
When test fitting the neck to the PP body, to make the screw holes line up with the body and the neck, the heel of the neck doesn't fit to the end of the neck pocket, I'd say there is about 3-4 mm of space, not an issue visually as the overhang from it being a 22 fret neck covers that, as does the pickguard, but would this affect anything sound wise (tuning etc..)?
I'm guessing / hoping not, just maybe the feel of things.
Clarification would be lovely before I commit to this though
Dave.
ON the T/C you got from me it would be right as all my necks and bodies are matched but the holes in the neck might not line up with other makers. That why if you buy a neck from me on it own there will be no holes in the neck, so you can drill the hole to match the body.
See the link below
http://www.stewmac.com/How-To/Online_Resources/Fretting/Scale_Length_Explained.html
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Instagram
