How does 50's style work? Diagram/link? Paul
It retains treble better as you turn the volume control down.
Thanks @ICBM.
Here's a diagram if it helps. The tone pot middle lug should either be grounded on the pot body either be bending it back and soldering or using a piece of wire to effect the same.
Another thing you could try is a no load tone pot. I've got one in the bridge of a P90 SG special I have and it does allow a little extra rawk from the P90 if that's what you want, as soon as you move the tone control off ten, it's back to normal.
oops .. no idea why both your earlier posts didn't show up when I looked earlier! .. sorry for duplicating >:D<
