Hi ,
Hope someone can help. I'm trying to make a dual latching footswitch with one switch to change channels and another switch to switch effects on/off on an amp. I want to wire this with a stereo jack and two DPDT footswitches (so I can add an led indicator at a later stage). For now, I just want to wire the stereo jack on to the dpdt switches but cannot find a diagram anywhere. I cant read schematics and the closest I can find is this but it is using SPDT switches:
http://i28.photobucket.com/albums/c243/Ian_Lea/Untitled_zpsdace595f.jpg
Can I just use the left side of a DPDT switch wired as above? If not, if anyone has a similar drawing using two DPDT switches, I'd appreciate it.
I already have 2 spare DPDT switches and a stereo jack which is why I want to use these rather than buying more bits.
Cheers
Ian
@mrn1989 - thank you! That's exactly what I was after!
I take it that the two colour led can show a different colour depending on which channel is selected?
