Try Studiospares or Thomann.
Of course, if you have a dozen true bypass pedals and no buffer, you probably want a buffer before you upgrade your cables
It's worth noting, it can't fundamentally alter the sound - it's just allowing a small electrical current to pass.
Anyway, van damme is very easy to work with, looks great, coils up nicely, is cheap, and doesn't sap a shit ton of treble from your signal.
A buffer - basically, this converts the signal it recieves into one that won't be affected by cable capacitance. Think of it as "preserving" what it gets. So running a 50 foot coil cable to a buffer will preserve a slightly deadened tone (think hendrix - or a prs sweet switch).
A shorter, lower capacitance cable will suck away less treble. A buffer after this will preserve that sound - it's why patch cables matter a lot less than the cable from pedal board to amp, and guitar to pedal board.
Some effects pedals have a buffer. Some have good buffers (such as the visual sound series, cornish pedals, klones and the like). Some are not so great (boss ones get some stick for leaky bypass or losing a touch of volume - both can be sorted by having another buffer in front apparently )
Van damme is low capacitance enough that it's only going to really bother you when it's getting quite long.
Remember, a lot of cable reviews online are coloured by price, bias, numbers and bullshit. It transfers an electrical signal, nothing else. It can't give a "colourful midrange" and a "sweetness" or a "tight low end" - it can only remove content, and that's mostly treble as far as I know.
if you use active pickups, you don't need a buffer at all. They drive long cables fine, so buffers are meaningless. As are expensive low capacitance cables.
I'd buy cable (personally) based on ease of use and how well it behaves when coiling it up, as well as how resilient it is to being stepped on and van damme pro has not let me down.
A 2 or 3 metre lead will not suck any tone if followed by a buffered pedal - I'd only really start noticing loss after 3 metres, and quite slight. Coily cables are the worst - because they're so bloody long! However, some people like the slightly attenuated treble, and my mate uses one for bass because it basically stops it sounding harsh (no pedals, just long Coily cable into amp).
http://www.maplin.co.uk/p/van-damme-pro-grade-classic-xke-instrument-cable-black-priced-per-metre-n98jt
The influence of a cable in that lot is probably fairly negligible. And the capacitance of the cable is 'part' of the tone. We're not looking for flat responses/hi fi qualities in a guitar set up.
