SPEAKER IMPEDENCE CALCULATOR
If money is no object, Roger Mayer VoodooVibe
Then the Mayer mini Voodoovibe also v good.
Sub 200, the Sweetsound MojoVibe is an utter killer- probably the best all round option- truly fantastic and over at the Gilmour Forum it's truly the Vibe of choice.
Fulltone Custom (or Gold/White non Wah enclusre) DejaVibe (others not that great IMO)
Budget range- the Voodoolabs Micro VIbe and BBE Vibe both are basically the same Mason....err...I mean pedal, and are both fabby.
Also, the MXR Phase 45 is very good at being a Vibe
The Mobius does a good vibe too, and you can set it on delay trails only.
EDIT: If you want the BBE one I know where there's a brand new one going for £100.
EDIT 2: another belter is the Villanova FX Vibe.
The Roger Mayer VoodooVibe is the business but a tad expensive. From personal experience I've owned the Lovepedal Pickle Vibe which is pretty good but with only one control knob a little limiting with what you can do.
I recently picked up a 2nd hand Fulltone Deja Vibe off ebay for under £130. I really like it. It has both chorus and vibrato options with a modern and vintage modern switch. With level, intensity and rate controls it's quite whereas the Pickle Vibe is a one trick pony.
EDIT: which means buying used makes sense.
Someone can prob explain this optical cell better?
So much info. Thank you
Fire up the YouTube!
In the European Union, the production and distribution of Cd-based photoresistors is banned since January 1, 2010. The initial version of the EU Directive on the restriction of hazardous substances (RoHS), adopted in 2003, allowed the use of cadmium in the devices that had no Cd-free counterparts.[35] However, in 2009 the European Commission excluded Cd-based ROs used in professional audio equipment from the list of permitted devices
In terms of vibes I've used:
Foxrox Aquavibe - amazing build quality and versatility but a bit too hi fi and wishy washy sounding for me. Waiting list massive too.
Fulltone Dejavibe - I had the mk 2 big treadle version. Sounded good but could never get an intense enough sounding effect. Good for Gilmour not so much for Hendrix.
Prescription Vibe Unit - awesome. Big thick swampy tone, plenty of intensity and depth and sensible speed range on the LFO. Shame it's so massive !
