I received a significant investment (about 80 quid!) in Planet Waves solderless FX patch leads today and in the main the process is very good and I managed to redo my pedalboard in 3/4 of an hour - thats 14 jacks, they all worked first time with no soldering, burnt fingers, swearing etc, however several don't stay in the pedal socket, I push 'em in and after a few minutes they pop out, they are still connected,but don't seem to latch, if the cable is U shaped between 2 pedals all is well but some of mine are not U shaped and cannot be, I've opened some pedals and bent the jack socket tab a little to get a more positive latch (they were OK with "normal" jacks). Trouble is I have a couple of mini pedals by TC Electronic, I don't have the correct size tork driver to undo the back, but I suspect the sockets are the plastic, no adjust type, so now I have to come up with something to maintain a positive pressure on the jacks to keep 'em in….Bugger!
Attached are a few photos..
1st In a Kit built Buffer note how the jack doesn't latch...
2nd with bent jack tab to make a proper latch…..
3rd with digital calliper length from face to edge of insulator on Planet Wave Jack
4th length for face to edge of insulator on"standard" jack…0.5mm difference…..
Anyone else had issues…….
Stranger from another planet welcome to our hole - Just strap on your guitar and we'll play some rock 'n' roll
Spot on. Their guitar leads are utter shite with a high failure rate.
Dare I say the OP should have used KaBL. Always first class service.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Have had one cable go a little crackly in 13 years of gigging for a living. They get the job done.
I've stopped using PW after having 2 cables get stuck inside the jack sockets of my V-drums .
