After years of playing off the back line our drummer has suggested I go through the PA..to control the sound better... has a 7 k watt pa system and right now the drums keys and vocals go through...me and bass on backline.....hes just a good mic for guitars so got everything ...
The problem is iv always played from the amp only and turn it up to get the sound I want out of the guitar and amp ...by playing at lower volume will I loose that ....so basically any tips and advice I should know and should it be a improvement ..thanks in advance
Just mic or di it, set the amp for the minimum volume you need to hear it onstage, adjusting the position to get the most out of it.
Check everyone else can hear you - I often end up a little louder than I would choose so that someone else can hear what they want. Then adjust the PA volume so the mix out front is right.
Hopefully if all works to plan, the stage sound will be a little quieter and more controlled and the guitar sound will have a more even coverage around the room.
